502 Bad Gateway for Admin
Cant get into my Admin area since installing WPMUDEV. Front of site shows fine. Jetpack not enabled.
Similar issues found didnt help solve problem
  • Nithin Ramdas
    • Support Wizard
    Hi Sun Country Marine,
    Hope you are doing good today. :slight_smile:
    Could you please try deactivating the plugins to rule out any conflict, you’ll have to make use of a FTP client, and rename the plugins folder located under /wp-content/plugins, in order to deactivate the plugins.
    You can then log back into you dashboard, once you have logged back in, you can rename the plugins folder back to the real name, and perform a plugin conflict test, as illustrated in getting support manual (flowchart), and rule out whether any plugin is causing this issue.
    http://vvpmudev.com/manuals/using-wpmu-dev/getting-support/
    Please let us know how that goes, so that we could give a closer look. Have a nice day. :slight_smile:
    Kind Regards,
    Nithin
